Old 08-15-2007, 06:40 PM
canker4077's Avatar
canker4077 canker4077 is offline
Exclamation Some issues
Okay I just got my geo it has 185,000 miles on it, runs great but the heater/air just stop working while I was driving, I need to first check the fuses but I have no Idea where they are? , and I am hoping its not the blower motor, If anyone else had this problem it would be nice for any help, thankssss
Old 08-15-2007, 06:58 PM
Syndrome Zed's Avatar
Syndrome Zed Syndrome Zed is offline
Re: Some issues
I assume you mean there's no air blowing even when just the fan is on? Yeah, definitely sounds like a fuse if not the blower motor. I haven't heard anything about the blower dying much, so it's probably a fuse. The fuses are under the dash on the driver's side, next to the kick panel, in a white plastic enclosure. There are a few relays also - on the driver's side, just in front of the strut housing and next to the battery, in a black plastic enclosure. I can't remember which fuse the blower motor uses, though.
Old 08-15-2007, 07:49 PM
Hugemoth Hugemoth is offline
Re: Some issues
Another common problem with these cars is the fan switch coming apart which causes the fan to stop working.
Q
Old 08-15-2007, 08:37 PM
canker4077's Avatar
Re: Some issues
wow thanks this helps, I will give it all a check
Old 08-15-2007, 10:52 PM
RossT RossT is offline
Lightbulb Re: Some issues
also make sure you check all of your ground wires in the engine compartment.
I was having an issue with my ac. It would just stop working. The light would be on in the dash, but no condesor fan was running. Somedays it worked for a while then it would stop. I traced it down to a ac ground wire on the passanger side firewall.
