Old 08-15-2007, 06:23 PM
malroy malroy is offline
1997 F150 4x4 4.2 AT engine removal
Removing bad motor. I have loosened all but the engine to trans bolts. Can,t get to the top ones. How do I get the clearance to get my hands and tools in there? I have the throttle body air plenum removed.
Old 08-16-2007, 08:36 AM
taillight taillight is offline
Re: 1997 F150 4x4 4.2 AT engine removal
Either drop the transmission tail down or pull the transmission. I usually pull the trans. with the engine. Either way you still have to remove the transfer case first.
Old 08-18-2007, 09:07 AM
I feel sure my 4.2L has crankshaft/rod problems. Can I pull the intake manifold and heads to get clearance to remove the top two engine to trans bolts. Pull the old block. Then intall a remanufactured short block. Bolt it to the trans then install the heads and intake.
Old 08-18-2007, 12:11 PM
Maybe but there is still not much room. Make sure you unbolt the torque converter from the flywheel befor you pull the engine.
