Old 08-15-2007, 04:44 PM
ljw5491 ljw5491 is offline
No Power Steering Assist - '02 5.3 Silverado Z71
I am wondering if anyone here has had this problem before:
When I turn to the right at low speed (from stop up to ~5 mph) there is no power steering assist. Left turns at all speeds operate normally. Fluid level checks out ok, so I'm trying to choose the next course of action. Dealer Parts Dept. says it might be a stuck flow meter, but hopefully the knowledge base here will give me more than a hunch... Any insight into this problem is highly appreciated.
-Larry
Old 08-15-2007, 10:57 PM
fillupread fillupread is offline
Re: No Power Steering Assist - '02 5.3 Silverado Z71
Interesting! My first hunch is a rack but you could have a steering box instead.
Does the pump whine when you loose steering? What does it do at idle sitting still while turning to the left?
Old 08-16-2007, 06:16 PM
Sitting at idle, turning to the left is normal (full assist). Turning to the right doesn't so much make it squeak as it does hiss!
Old 08-17-2007, 12:54 AM
You lost me on the second sentence. If I read that right there is no power assist while turning to the right at idle.
Old 08-17-2007, 08:53 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
YOu may need to just flush out the power steering fluid. it will get rid of the gunk in the box that could be causing your problem.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 09-20-2007, 10:13 PM
ramgabe1027 ramgabe1027 is offline
Hi guys. I have a 99 silverado 5.3L. I had same problem. only when i was getting out of a parking lot, turning is a hastle. I had to hang from the steering wheel to turn. At speeds it was fine although noisey. Fluid was spilling out of the resivoir all the time. I checked the fluid and it was dark brown! I flushed it and ever since its been like Feb of 1999 when i drove it off the lot!!!
mod: K&N FIPK, Flowmaster big block series (true dual no cats), Hooker ceramic coated long tube headers, Diablo Sport power programmer, 2 inch suspension, Pro Comp A/T 315/70 R16, rhino full guard, toolbox.
