Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 08-15-2007, 02:15 PM
canvas's Avatar
canvas canvas is offline
Headlights ??
Hey,
The Lebaron(1987) has 4 headlights 2 lamp sealed single beam 2 lamps double beam hi-lo- not sealed.
When i turn on the lights (pulling the knob) one klik nothing happens, the second klik the low beam works, with the lever for turnsignal i can turn on the hi beam.
But the singel beam will not turn on, when do they light up??.
Thanks in advance.
Greetings from the netherlands.
Old 08-16-2007, 06:55 AM
taillight taillight is offline
Re: Headlights ??
Do you mean the running lights? Same bulb as the turn signal but a differant filement.
Old 08-16-2007, 08:28 PM
mopar or no car mopar or no car is offline
Re: Headlights ??
are they in the bumper like foglamps? cause i think those are turn signals/running lamps. all the first click does is turn on the running lamps, though if you wanted to add fog lamps you could use that circiut
if it isnt a mopar, you shouldent be driving it
Old 08-17-2007, 10:20 AM
canvas's Avatar
Re: Headlights ??
Hello,
Not the light in the bumper, the headlight above the bumper.
See link http://replacement.autopartswarehous...20Beam&dp=true
On the left and right side are a pair mounted.(total of 4 lamp are mounted)
In two mounted on the inside have hi beam and a low beam combined double filament.
The 2 on the outside are single filament lamps so one beam only, but i don't know how to turn thise on.
When shoud the light up??
Old 08-17-2007, 10:28 AM
Re: Headlights ??
The two outside, single filiment are also high beam. Should light up when you turn on high beam.
Old 08-17-2007, 11:37 AM
canvas's Avatar
Re: Headlights ??
Thank you,
I try to measure the voltage with the ligts on, it is my mistake forgot to test with the hi beam on.
I presume the where low beam lamps.
Going too check right now.
Gr Paul
Old 08-17-2007, 11:53 AM
canvas's Avatar
Re: Headlights ??
Yep,
Correct it's a hi-beam, both of the lamp are broken.
So the will never lit up, going to find replacement not very easy but i'll manage.
thanks for all the reply's
Paul
