Go Back   Automotive Forums Car Chat > Cadillac > Escalade | ESV | EXT
Old 08-15-2007, 12:54 PM
eddie8 eddie8 is offline
fuel pump
On a '99 Escalade, do I need to remove the tank, or is there an access panel for the fuel pump? Thanks.
Old 09-08-2007, 07:02 PM
envoyxuv envoyxuv is offline
Re: fuel pump
Fuel tank removal is necessary to replace the fuel pump.
Old 09-09-2007, 06:10 PM
rhandwor rhandwor is offline
Re: fuel pump
Only if you use a reciprocating saw.
Old 09-20-2007, 01:09 PM
sukrluv sukrluv is offline
Re: fuel pump
i had to remove a fuel pump like 8 times u have to remove some of the exhaust in order to get the tank to drop and make sure you use a jack to lower the tank as fuel is heavy. u will also have to move and manipulate some of the fuel lines that run to the engine while doing the lowering. make sure you release the hose to the filler cap also from underneath, easy clamp but pain in a$$ if you start lowering and bend or possible crease or crack the rubber.
Old 09-20-2007, 08:00 PM
Re: fuel pump
Was this your own vehicle,at dealer prices you could come close to buying a new vehicle.
Was any other causes found on this vehicle?
