'96 Civic Engine Issues
Hey all, I'm having issues with my honda civic. First of all the check engine light is on but I had that checked out at autozone and the machine said that was a catalytic converter failure, with a number of possibilities causing it including engine problems. Just curious if anyone knew exactly what a catalytic converter failure is going to mean to me.
However, my real problem is this, the engine is making a wholllleeee lot of noise at low rpms and when stopped, it sounds like a fast rattling almost, and when I opened the hood to listened, it sounded more like it was coming from the radiator, but I'm no car expert, but I was wondering if anyone had any experience with lots of engine noise at low rpms, and the noise stops when I hit the gas and the rpms go higher. Alright take care. Thanks! |
Re: '96 Civic Engine Issues
There's a lot of things that can be and if it's really coming from
the engine it probably is a serious issue. One that could only be truely verified by tearing it down and looking. Sounds like maybe a loose rod, but maybe a valve train problem that could easily be fixed by pulling the valve cover and readjusting the valves. To many things to try and guess without hearing it. Get a stethascope and isolate where the sound is coming from. that'll narrow the possibilities a lot. Most catalytic converters go out because of a different problem, like dumping unburned gas in them. They are usually the result of another problem. They don't die, they're usually murdered.
Jim C. |
