Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-15-2007, 08:10 AM
MAP3K MAP3K is offline
1996 Crown Vic. Trouble codes
How do I get the Trouble codes on a 96 Crown Victoria 4.6 (W)?
Old 08-15-2007, 05:53 PM
reekor reekor is offline
Re: 1996 Crown Vic. codes
They are listed on a white sticker on the drivers door.
Originally Posted by MAP3K
How do I get the codes on a 96 Crown Victoria 4.6 (W)?
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-15-2007, 07:05 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
What kind of codes are you looking for? Build codes, trouble codes what?
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-16-2007, 05:28 PM
Trouble Codes
Old 08-16-2007, 06:49 PM
way2old's Avatar
TOKEN HILLBILLY
You will need a scan tool. Autozone, Pep Boys and some other parts houses read the codes for free in the hopes you buy somethiong from them.
Old 08-16-2007, 11:49 PM
A FORD WDS OR NGS DIAGNOSTIC SCANNER WILL GET YOU THE CODES.
Trouble Codes
Old 08-17-2007, 04:34 PM
carlos80 carlos80 is offline
Actually just about any code puller can get you the DTC s. Try Autozone they do it for free.
Old 08-18-2007, 11:43 PM
Only if it was that easy.unless the op only wants generic engine codes.
Old 08-19-2007, 10:11 AM
way2old's Avatar
TOKEN HILLBILLY
Generic readers also pull Manufacturer's code. All the description says in manufacturers specific. On generic codes they give the componet name.
Old 08-19-2007, 12:21 PM
Sure, how about sub systems like air-ride, abs, lighting control module, drivers seat module, climate control module.
Old 08-19-2007, 12:31 PM
fleettech fleettech is offline
We use PDS to get the codes
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 08-19-2007, 02:07 PM
way2old's Avatar
TOKEN HILLBILLY
reekor and fleettech. We also use the NGS, PDS, Genesis, Nemesis. Most people that are concerned about warning lights are concerned about the check engine light. Most sub systems do not turn on the check engine light. So I feel most people want the cheapest diagnostic they can get for the light. Generics are good to give you a starting point. I don't know of anyone that has bought the Ford specific scan tools that will read codes for free. I personally purchased the PDS and I charge for the use of it, just because of the cost of the tool. Specific manufacturers tools for each manufacturer would be the ideal world, but how many techs can afford to do that? I do agree with the specific tools being better, but look at the cost factor to the consumer.
Old 08-20-2007, 01:57 AM
There is nothing wrong with generic scan tools for basic info if you have a good service manual they can go a long way. I just find that most people that own them waste more money and time on repairs then the people that don't own them. I see it all the time where someone gets a low egr flow code and they run out and replace the egr valve just to get the same code come up again a few miles down the road.
Old 08-20-2007, 01:21 PM
I believe that generic scan tools can do more than just basic info. It really comes down to who is using it, and what they can do with the information they get from them.
