Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-15-2007, 05:55 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
'84 Caprice brake lights stay on
This happens once in a while and I have to check it every time I park the car. My brake lights stay on! If I play with the pedal, lift it with my toe and don't slam the door too hard, I can get them to stay off.
Is this an adjustment or is the switch bad, how accessible is it? I have about an hour or so tomorrow after work to mess with it.
Thanks, Bob
Old 08-15-2007, 10:40 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: '84 Caprice brake lights stay on
Thanks, Bob
Sounds like the brake switch slipped a little. I've had this happen before, once. Just readjust the position of the brake switch, under the dash. It's easy to get to. Move the switch a little closer to the brake pedal arm.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-15-2007, 11:56 AM
bobss396's Avatar
Thanks, I'll try that first.
Old 08-16-2007, 01:52 PM
bobss396's Avatar
I cracked a 40 of OE last night and gave it a look see.
I saw what you meant about adjusting the switch so the plunger was closer to the pedal arm. Since I was in no mood in turning upside down under the dash, I happened to have a ty-rap in my ash tray.
I wrapped it around the pedal where it meets the plunger, made sure it was tight, problem solved! Again, silicon saves the day.
Bob
