Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-14-2007, 11:54 PM
Andykid456 Andykid456 is offline
Tech help with main fuel line
Hey guys im not 100% if im in the right fourms but i need some seggestions or help should i say the main fuel line which hooks up to the bottem of the gas filter cracked im not sure if i want to replace it or if its possible to fix what i have. i was wondering if i can go to a local hardware store and buy new hose to run from the tank to the fire wall if so what kind should i use? or if i was to fix it can i use an compression adapter? and if not where can i get hose from to make this work because i really need a running car at the moment thanks alot for you time im sorry about the other posts
Old 08-15-2007, 12:30 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Tech help with main fuel line
First, dont type in that big ass font.
Now, where exactly did it crack. Im think right after the fuel filter. How far? you might could cut that section out and use a small piece of fuel hose to connect them together. Other than that I dont know of anything with out replacing the whole line.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-15-2007, 03:10 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I don't mind at the moment, I'm a little drunk and its easier to read... lol
I don't think he'll be able to do that because of the pressure that runs on that side of the fuel rail... Right? He will probably have to go to a dealership and buy a new tank to filter hard line to replace that one since its all pressurized... I really don't know if a compression adapter would do much good in this situation... Isn't stock fuel line pressure like 36 or 42psi or somethin? Whats the adapters good for?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-15-2007, 09:42 AM
Hey but if i replace the whole thig where ca i get the pipe from would i be able to get bratied line from hardware store and another thing it broke about 4 inches thanks
Old 08-15-2007, 10:18 AM
Holset powered 420a
Im not even sure what car we are dealing with here. This the the line going from the filter to the tank or the the line going to the fuel rail. If you want to replace the whole line just order some steel braided line from jegs or something with the fittings you need. That would be the cheapest/best way I can think of. Shouldn't cost much more than 65 or so.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-15-2007, 11:10 AM
You could do braided line with all the proper adapters... If you do another stock hard line though, you can get it from a Mitsubishi dealership, assuming we are talking about an Eclipse here... After reading back through, you didn't mention a model or anything...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-15-2007, 09:21 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Either way, you're going to need a special high-pressure fuel line, whether it be a special braided FUEL line, or a hard line from the tank, but some hose and a compression fitting from your local hardware store will NOT work, and you'd probably catch your car on fire after that baby broke and spewed fuel all over the hot engine.
95 Talon TSI AWD
97 Eclipse GST
Old 08-15-2007, 10:13 PM
Hey well ill get my facts straight lol its a eclipse gsx and im talking about the hard line running from the tank ro thr filter not the line that goes from the filter to the injectors well anyway it cracked about 4 inches down of the gas filter i was hindering if i can hook up a different fuelline like a bigger one from the tank to the filter i have a stock fuel pump i was just wondering so i can get more fuel i guess can you guy give me a few web sites that i can order the line from i most likely want an aftermarket line steel braided. along with the line comming from the injectors to the filter thanks for your time
Old 08-15-2007, 10:30 PM
Holset powered 420a
If I was you I would just replace it with a stock part. Its a small line and wont cost that much. The stock lines will deliver plenty of fuel. Im not even sure what they max out at but it will take a lot. If you want more fuel just get a bigger fuel pump. But if you want to upgrade I would order the parts from Jegs. You could probably go with a 4AN line. You could go with a 6AN but that might be a little overkill.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-15-2007, 10:42 PM
hey so i can get it from a dealer ship do tjey stock these parts or pobably not and by the way can you send me a link of jegs the kit i need because i dont whant that fuckin hard pipe to crak on me again and can you give me a price range of them noh thanks
Old 08-16-2007, 12:00 AM
Holset powered 420a
Im sure they would have to order it.
http://www.jegs.com/webapp/wcs/store...10019_-1_10267
SS hose - $40
Fittings - $30 to 40 maybe
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-16-2007, 06:14 AM
I would just replace it with another stock hard line. It will support plenty of flow for as much fuel as you will ever need on that car. Also, its dirt cheap to get another hard line as opposed to braided line and fittings...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
