Old 08-14-2007, 04:59 PM
nrizzo nrizzo is offline
tire size
i have a 2004 2500hd ext. with 245-75-16. what is the largest tire size i can put on this truck without any type of lift? also with larger tires will it throw off my spedo?
Old 08-14-2007, 05:43 PM
bigbadram51 bigbadram51 is offline
Re: tire size
Shoot with a HD you could probably squeeze some 35's in there with a torsion bar crank (on stock wheels of course) and an alignment. So less than a hundred bucks. 33's will fit right now as is EASY. Larger 33-35 will throw it off by about 10% give or take.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 08-15-2007, 03:07 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: tire size
Cranking the torsion bars throws the alignment off. 285/75/16 should fit as-is
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 08-15-2007, 03:29 PM
Re: tire size
Yeah, thats why I said tb crank and alingment... As long as you dont crank to much alignment is easy to re-achieve. The only down side to a TB crank if you crank to much is rough ride as you reduce downward wheel travel and over stretching shocks and over-cranking without new UCA's is premature ball joint wear. 1-2 inches on an HD is easy and no real noticeable difference in ride and performance. There are guys with HD's and Ford index keys with new shocks getting 3" front lift for a few hundred dollars. Gotta love those HD CV axles.
3" PA Body Lift
Covermaster Top
