Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 08-14-2007, 04:54 PM
coopdavillage's Avatar
coopdavillage coopdavillage is offline
Question 95 Check Engine Light reading
so i have a 95 tracker 16 valve, 4x4 and when reading the manual it says to jump a connector in the engine compartment (specifically says 4 pin by the battery) but i dont have a 4 pin by the battery like it says all i have is a 6 pin. anyone have any idea of which connector i need and which ones i need to jump to get it to read me the codes?
thanks in advance
Old 08-14-2007, 11:50 PM
edmcm2000 edmcm2000 is offline
Re: 95 Check Engine Light reading
For a picture, description of how to, etc: Look here, Ed
http://www.autozone.com/newGuide,yes...epairGuide.htm
Old 08-15-2007, 08:37 AM
thanks ill give that a try
Old 02-10-2010, 12:13 AM
Ok it has come to the point that i need to revisit this because everything that I have found points me in the wrong direction. The Haynes manual that I have says that there is a 4 pin connector that you jumper between 2 and 3 by the battery and then turn on the ignition and it will give you the codes. I have attached a picture of that area and i have tried all of the connections in that area but nothing gives a code. Does anyone know if there is something that im missing? Or am I looking in the wrong spot? I'm resorting to this because I need to get my car tested for emisions and the check engine light is on and it costs $85 to get it checked and none of the auto parts stores checks can read the codes....
Thanks in advance
Old 02-10-2010, 12:52 AM
OK never mind on this, for some reason it took some weird searching but i actually found a post on here for it.
Posted by Hesszoo:
6 pin connector by the battery with a cap.
1 2 3
4 5 6
1 - Has no wire
2 - Diagnostice Request Terminal, Blue with Yellow stripe
3 - Diagnostic Output Terminal, Purple with Yellow stripe
4 - Ground Terminal, Black
5 - Test Switch terminal, Blue with Red stripe
6 - Duty check terminal, Purple
I jumped terminal 2 with terminal 4 and got my codes, I had 2, a 13 O2 sensor, and 51 EGR. Iwill test them tomorrow and then change what I must.
I just wanted to say thanks for trying, and also let others know what I found.
