Old 08-14-2007, 02:35 PM
dhrubio's Avatar
dhrubio dhrubio is offline
Send a message via AIM to dhrubio
Electrical Problem
A couple days ago I was messing with my fogs to get them to work independent of the high beams. Got it working fine. Then I was still bored so I continued on to get the fogs to work with the parking lights. Now my low beams, highbeams, fogs, or parking lights dont work at all! I checked all the fuses in the box under the dash and the box in the engine bay on passenger's side with a test light, and all fuses are fine. Bulbs are also fine. Somebody enlighten me please!
edit- forgot to say that my voltage is unusually high now. Before it would be at about 13-14, now it stays at about 15.5
Pics
Old 08-14-2007, 05:31 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Electrical Problem
Check out the altenator fusible link.
Old 08-14-2007, 05:44 PM
AutostradaVR4 AutostradaVR4 is offline
i wanted to do that too...make it so my fogs worked whenever the button on the dash was pushed, but still went off with the ignition.
how hard was it? wouldnt wanna give me a walkthrough would ya? lol
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 08-14-2007, 07:04 PM
dhrubio's Avatar
LOL well not yet since none of my lights are working, but once I fix everything (actually my neighbor lol he's helping me) Ill let you know.
Can someone please give me the wiring schematics for the headlights, tails, and fogs please, thanks!
Pics
Old 08-14-2007, 11:16 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
hmmm, sounds to me like youve just screwed up a connection, double check all of those and make sure that the wires are connected to the right ones. When soemthing goes bad with the lighting system on these cars the whole thing goes down.. anslo, check the bulbs, sounds weird but once i had bumped a buld and it was grounding out or something causing none of my lights to work... very strange lol.
EDIT: I also, would like to know how your wiring the fogs to work with the parking lights!
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 08-15-2007, 12:25 AM
dhrubio's Avatar
Well I must have just connected a wrong wire because everything was working fine until I start messing with the wiring for the fogs. Me and my neighbor believe I gave ground to a power wire in the tail relay, causing a fuse to blow or a short somewhere, but we have no idea where. So we need the wiring diagrams to figure it out.
-Once I fix it I will let you guys know how I did it.
But for now, somebody please get me those diagrams
Pics
Old 08-15-2007, 04:39 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
best thing to do to find the problem would be to back track
until you find the problem, step by step
Old 08-15-2007, 01:49 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i can get you the circuit diagrams. first i need to know the 1) YEAR of your car and 2) does it have stock alarm system?
honestly, the best thing would be to get a service manual on CD. PM me your address and i'll mail you a copy for future use. but i'll still email you the circuit diagrams.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-15-2007, 06:05 PM
hot3000's Avatar
hot3000 hot3000 is offline
i wish i could get a service manual on cd
speaking of which, i need to go buy a owners manual and service manual
Old 08-15-2007, 07:38 PM
Linebckr49's Avatar
hot3000, PM me your address and i'll send you one as well. you don't need an owner's manual. its worthless and just tells you how to turn the car on and what all the buttons do, nothing a monkey can't figure out.
93 3000GT base
Old 08-15-2007, 09:17 PM
hot3000's Avatar
haha sweet, PM Sent, thanks
