Old 08-14-2007, 08:43 AM
Dodge Stratus Dodge Stratus is offline
hifonics brutus bxi 2006d and system questions
hi, my friend just got 2 dual voice coil 4 ohm kicker 15''(1000max-500rms) and a hifonics brutus bxi 2006d amp. the amp says it is a 1 channel...but why does it have 4 connections? it has two positive and two negative connections. we are trying to wire them to 1 ohm...parallel/parallel......right? when we hook one of them up it hits really hard,but when we stick the other speaker on it gets quiet and they dont do shit......can someone please help us out! oh one more question...is that amp really 2000 watts rms?
Old 08-14-2007, 03:27 PM
PlayStation3 PlayStation3 is offline
Re: hifonics brutus bxi 2006d and system questions
thats more like a 1500 watt amp. are you sure that everything i hooked up right?
Old 08-14-2007, 05:56 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
it has two sets of connections for flexibility .... you must be hooking something up wrong if it works with just one sub.
Old 08-14-2007, 07:34 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Have you tried wiring both subs in a parallel configuration to get the impedance down to 1 ohm and then connecting it to 1 set of the outputs. That amp is rated at 2000w at 1 ohm RMS. As to why there's two sets of outputs not sure about that.
Old 08-15-2007, 12:55 PM
well we found out the problem. one speaker was wired wrong. we had the positive wires on the negitive connections...now everything is working properly. it hits hard as a mother!!!! thanks for the help anyway!!!!
