Old 08-14-2007, 08:37 AM
SunAllied SunAllied is offline
How to Replace Spark Plugs for 1999 Olds Intrigue
I took off cover and I don't know how to replace the spark plugs
Old 08-14-2007, 09:36 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: How to Replace Spark Plugs for 1999 Olds Intrigue
Which engine do you have 3.5 or 3.8?
If its the 3.5 you might find this post helpful.
http://bonnevilleclub.com/forum/view...ht=spark+plugs
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-14-2007, 01:56 PM
alejmr alejmr is offline
and if it's 3.8?
Old 08-14-2007, 03:34 PM
LittleHoov's Avatar
If its a 3.8 the plugs are easy to find by following the wires going to them. The back ones are a little hard to get too, but the same engine rotation I mentioned in that post applies for the 3.8 as well, and it does help.
Old 08-14-2007, 04:21 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
I did my rear plugs without rotating the engine, didn't have much trouble at all - in fact the hardest thing was getting the coil packs off. I guess I had just the right combination of extensions and swivel ratchet to make it easier.
2003 Pontiac Grand Prix 3.8 Litre V6
ASE Certified Master Tech
Old 08-23-2007, 12:32 PM
s dinel s dinel is offline
I replace mine (2000 GL - 3.5L V6) easily without engine rotation. For the front bank used long (6") extension on my ratchet with a sparkplug socket (the kind with a rubber insert that grips the loose plug). The rear bank used same spark plug socket, short (3") extension and 1 U-Joint (swivel) socket. It is also helpful to have one of those inspection mirrors on a stick, to inspect everything prior to installing the new plugs. Mine had a lot of dirt and grit down by the spark plug holes, that I sucked out with a shopvac so it didn't interfere with the threads/torquing etc.
I agree that the hardest part was removing the coil pack, Next hardest thing was lining the rear coil pack up so everything was contained in the boots that was supposed to be.
Old 08-28-2007, 02:43 AM
ND4SP's Avatar
ND4SP ND4SP is offline
What ever you do, don't lose one of the bolts that hold the coil packs on , you will be needing to bend over. The bolts are 7 to 8 bucks a piece.... I lost one, right now my back coil pack is missing one, no problems yet.....
