Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 08-13-2007, 10:32 PM
terry LAMB terry LAMB is offline
96 Avenger
Hi all.Need some help.My 96 avenger starts hard then smokes black smoke till clears up.Then you try to accelerate and it dies unless you gun it.When you drive it there isnt much power.Please help.
Old 08-16-2007, 08:07 PM
growe58 growe58 is offline
Re: 96 Avenger
Is this the 4 or 6? The 4 is very sensitive to bad plugs or bad ignition wires. The black smoke usually indicates unburned gas, probably a miss. Does it seem to be missing? You can try disconnecting one plug wire at a time (make sure you're insulated!) and if the engine doesn't run worse, that cylinder is missing and you can investigate further.
Old 08-21-2007, 02:16 PM
new2mitsu new2mitsu is offline
Re: 96 Avenger
yeah, definately getting a misfire
