Old 08-13-2007, 09:09 PM
J_SHADOW J_SHADOW is offline
i need help any 1 please !!!
i got a crx SI
I just put on a d16 sohc vtec
the ECU is not getting power or is bad
no spark
cant hear the fuel pump prime
when i try to start it just keeps turning over
I checked all fuses ,in the motor compartment and inside under dash
and I replaced the main relay and I cant hear the relay click
the ECU is not even giving me the 1 flash hello sign.
could the main relay I bought be bad or the ecu be bad.
the check engine light does not come on
I also check the grounds on the motor what else should it be???
Old 08-13-2007, 10:36 PM
viper-blue's Avatar
viper-blue viper-blue is offline
Re: i need help any 1 please !!!
what ecu are you using...did you test the main power supply to the ecu to see if its getting a signal? I would make sure your getting power to the ecu before you suspect the main relay..get your manual out and test the power feed to the ecu, I know you checked the grounds..but make sure the thermostat ground is connected...when my z6 went in I had no ecu power cause I forgot to ground it ..little shit like that is easy to miss when your changing an entire engine...
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 08-14-2007, 02:42 PM
Ok Im Gonna Check The Main Power Like U Said And Im Also Gonna Sand Down All The Grounds And I Let U Know How Everything Goes Thanks
