Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-13-2007, 09:03 PM
Lude-icris Lude-icris is offline
94 sl2 wont start
it was sitting for a few months when i bought it so the batt had no charge so i charged it and it started first time i took it around the block and shut it off less then an hour later i tried to start it again and nothing all the interior power works but wont turn over?????
thanks in advance,
lude
Old 08-14-2007, 12:58 AM
Cat Fuzz Cat Fuzz is offline
Re: 94 sl2 wont start
Battery could be bad. The lights in a car draw very little power compared to the starter. A battery can power lights to full brightness but not have enough power to even make the starter solenoid click.
Old 08-14-2007, 01:47 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
why was it parked to begin with? could be a bad alternator, or a few other things, try a jump start and look for the battery dash light.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 08-14-2007, 10:06 AM
i bought it from my brother it was sitting at my moms cause he left it here when he moved to manitoba and he flew from alberta.....
Old 08-14-2007, 10:38 AM
denisond3 denisond3 is offline
If its an automatic, try wiggling the shift lever to make sure its in park - cause it wont start if the tranny thinks its in gear. If its a standard tranny, push the clutch pedal down and pump it up and down while you have the key turned - same type of reason, a safety interlock that might be cruddy from sitting.
If a car has been sitting a while, I always clean the battery posts and the battery cable terminals with the blade of an exacto knife, to get the lead-oxide off the surfaces.
Old 08-14-2007, 12:33 PM
i tryed the clutch thing and nothing the batt dont look to old and its side post(is top post better conestion wize?)and it is clean.....it looks as if he ran a relay switch for the rad fan it on the inside of the console is this ok???could it be the problem....also the tail lights and lighter dont work i checked the fuse for the lighter and its good and so is the one for the tail lights any ideas???
Old 08-15-2007, 01:00 AM
won't start and electrical assercys inop, sounds like a drained battery, again, try a jump start. do you have any power anywhere?
if the switch was wired so that the fan could run with the engine off that would drain the battery, otherwise it shouldn't be a problem.
the problem with the side terminal battery is that sometimes(very common with the AC Delco brand)they leak from the terminal. if the issue is not remedied, the acid/oxide build-up can damaged the battery cable as well.
Old 08-15-2007, 01:04 AM
Doesn't matter what the battery looks like. Take it out and have it tested.
