Go Back   Automotive Forums Car Chat > Mitsubishi > Mighty Max
Old 08-13-2007, 09:28 PM
willanddeb willanddeb is offline
1992 mad max truck 2.4l engne misfire code 41
1992 mitsubishi mad max 2.4l 4cyl m/trans check engine light on code 41 misfire #4 cylinder compression equal all cylinders, spark okay,injector drive okay
Old 08-14-2007, 06:26 PM
Delta Dart Delta Dart is offline
Re: 1992 mad max truck 2.4l engne misfire code 41
Originally Posted by willanddeb
injector drive okay
What do you mean and what tests did you perform?
Code 41 is an injector code indicating a possible short or open in the fuel injector harness, connector or injector coil.
Old 08-14-2007, 10:07 PM
Used a noid light to check injector drive. Flashes while cranking. compression is equal on all cylinders. New plug wires due to leaking spark. Check engine light on with code 41. Engine misfiring on # 4 cylinder. What kind of resistance should I have across the injector? What else do you suggest?
Old 08-15-2007, 12:47 AM
Fuel injector resistance should be 13 to 16 ohms. Visually inspect injector harness connector and wiring .With engine running wiggle wires and connector and see if check engine light condition changes. Wiggle wires and connector while checking for continuity with meter.
Old 08-27-2007, 09:12 PM
injector resistance 15 ohms all injectors; wiggling wires no effect; still missfire in number four cylinder with code 41 injector drive fault; no shorts or opens in harness; Is this a bad computer?
Old 08-29-2007, 07:35 PM
It is most likely the ECU.You have ruled out all the other items associated with DTC 41 condition. Is the engine actually misfiring or is the only symptom the CEL/ DTC 41?
Old 08-29-2007, 11:07 PM
It actually is misfiring in # 4 cylinder
Old 08-30-2007, 10:01 PM
Check PM
Old 09-16-2007, 02:00 PM
forsale123 forsale123 is offline
unplug number 4 while running note if any difference in running then switch 1 and 4 injectors
