Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-14-2002, 04:27 PM
un4gvnbb's Avatar
un4gvnbb un4gvnbb is offline
same
i checked all the wires before, even switching someof them around or running direct connections to the battery and ground (by the way, the head unit by default turns the volume up 1/4 of the way the first time you hook it up, when i directly connected the battery to the radio the radio started to turn it self up and then shut completly off). None of this works. i havent however checked to see if the wires have been mashed together somewhere. although it shouldn't matter if i did the direct connections. my brother is a mechanic and he said it could be something called the body control module (BCM). its an electrical sensor that does, uhh, something. anyway i think ill get that checked out. anyone hear of it?
Two cars, if trans pan gasket is same, is pan the same? rastoma Caravan | Voyager 2 12-25-2009 04:40 AM
Same FPR Same problem - 02 Venture and 00 Alero darnsuprat Venture 1 03-11-2008 12:42 PM
4cyl/8cyl..Same Car..Same Power.. solaris=amazing Engineering/ Technical 12 02-21-2005 05:04 PM
same ga, same security problem nova_gh Grand AM 0 08-25-2004 07:59 PM
