Old 08-13-2007, 03:28 PM
1BOSSMAN 1BOSSMAN is offline
Stalling
Hi I Own A 2000 Grand Am 2.4 Car Will Shut Off But Will Start Right Up Has A Small Hesitation When Throttle Depressed Has Plenty Of Power Has Been Tuned Up And New Fuel Filter 99000 Miles No Codes No Lights Except For 1 Time When It Wouldnt Start I Tried For 5minutes On And Off Then When It Started The No Trac Light On
Old 08-14-2007, 05:58 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Stalling
Sounds like you might need your injectors cleaned up.
Have you tried any injection cleaners ??
Seafoam works great!
Gm does recomend that the fuel system be cleaned professionaly about every 30-40K miles,
as these injectors and the lines get build up and can cause the injectors to clog/stick.
Might also check your IAC.
Idle Air Control(IAC) Testing Replacing for 99+
and Welcome to AF!
1999 Grand Am SS 3.4 OHV
Old 08-15-2007, 08:20 AM
Re: Stalling
had injectors cleaned at a fast oil change shop $79.99
they also did fuel filter and air filter at that time there was no problem about 4months later fuel pump went out replaced fuel pump and plugs didnt do anything with coils or plug wires!
what do you think about this maybe coilos bad but when it starts to shut off it jurks and idle gets rough.thanks
Old 08-17-2007, 08:38 AM
Re: Stalling
Cleaned the iac and no change but 2 days later no engine idles at 1000 rpm when cold than goes to 500 rpm and motor shakes like hell
Old 08-17-2007, 08:53 AM
Re: Stalling
Well I wouldnt trust an oil change place to check the air in my tires
The dealership uses a much better cleaning system
Kinda like this.... Napa sells the kit for around $300.
I'd try changing your spark plug boots!
Then if that doesnt work test or get the coils and ICM checked out.
Good Luck
Old 08-17-2007, 01:23 PM
Re: Stalling
Yes That Would Be Nice But Theres No Place On Fuel Rail To Screw On On The 2.4
Old 08-18-2007, 12:01 AM
Re: Stalling
No but they sell the hose and connector(s) needed with the fuel gauge kit.
Yea big pain in the butt
Old 08-18-2007, 07:20 AM
Re: Stalling
Yea Just Found Out I Bought A Kit From Napa Willmuse This Weekend And Let Board Know After Findings
Old 08-21-2007, 07:02 AM
Re: Stalling
well ran fuel injection and changed plugs and oil again and now its worst any input
Old 08-21-2007, 02:01 PM
Re: Stalling
Probly the ICM or coils are bad, get them tested.
Typical when all the heat being trapped under the top cover.
Old 08-24-2007, 08:42 AM
Re: Stalling
Now I Am Getting Code 0441 Please Help I Know Its Evap Or Purge But Do I Just Replace Them
Old 08-24-2007, 01:32 PM
Re: Stalling
A p0441 is - Evaporative Emission Control System Incorrect Purge Flow
Did you overfill your gas tank, or just fill up ?
Evap codes are tricky to track down, check out this thread for more details.
The GAS CAP code!!!!!!!!!!!!!!
Old 08-25-2007, 10:12 AM
Re: Stalling
Wife Says She Always Sticks As Much In As Possible And Says Last Time A Little Leaked Under Car
