Old 11-14-2002, 03:26 PM
Guido Guido is offline
Question Revell Porsche 930 Turbo - Help needed!
Hi guys,
A quick question. Does anyone from you have this Revell Porsche 930 Turbo 'Premium' kit at home, or at least the instruction sheet. I'm looking for the partnumbers of the front and rear windows. They were broken in the box and I have a Fujimi one. Fujimi 'Enthousiast' and Revell 'Premium' are the same, so if anyone could tell me the Revell partnumbers I can get them from Revell parts department in Germany.
Help is really much appreciated
Thanks in advance,
Guido
Old 11-14-2002, 04:09 PM
BVC500 BVC500 is offline
That's a pretty old kit and unfortunately, you most likely won't be able to get parts for the kit anymore.
Old 11-15-2002, 12:22 AM
mel79's Avatar
mel79 mel79 is offline
I believe window parts are the same in all the Fujimi Porsche 911 coupes of the same era, so you should still be able to order replacements from Fujimi.
-Mikko
Old 11-15-2002, 01:36 AM
Sure thing it's an old kit. Don't know where I could get parts from Fujimi in Europe For Revell however I know where to get them. And they are able to supply some really old parts to. I've visited the factory in Gemany once. That's how I know and that's why I'm trying to get the Revell partnumber.
So anyone else?
Old 11-15-2002, 01:48 AM
wkma7six wkma7six is offline
Huudo, go to this link:
http://groups.yahoo.com/group/gpma/
You will have to join the group to post messages, but the guys in there are of the more "mature" generation and are very into racing subjects and older kits. I'd recommend you give your inquiry a try there. My ex-GF bought me a Fujimi Ferrari Dino 246 gts without instructions at a show and several of the guys responded within a few hours. About one week later, a new set of photocopied instructions were in my mailbox.
Good luck Huudo
-Walter
Just finished: TURBONIUM
Rosy the Turbo Beetlehttp://www.automotiveforums.com/vbul...9&goto=2072489
Old 11-15-2002, 09:07 AM
Thanks for the tip, but probably it's just me, but I found it really hard to register there. And then when I tried to post something I got an error message. Anyway, will give it another go. Probably I'm just getting to old
Old 11-16-2002, 08:41 PM
GTI1800's Avatar
GTI1800 GTI1800 is offline
Send a message via ICQ to GTI1800
Réponse en image....
Salut Huudo,
je préfère te répondre en français, cela ira plus vite....
Bon, écoute, j'ai photographié deux PORSCHE............
Une 930 TURBO (fujimi/TESTOR) et
une 911 TURBO (fujimi)
La notice est la même, tu trouveras le détail ci-dessous.....
Si tu as une autre question, écris moi.....
J'espère que cela t'aidera......
Laurent.......
Merçi pour les répliques de ta part lors de mes new threads.....
2 205 GTI 1900 1988/1992
Old 11-16-2002, 08:46 PM
GTI1800's Avatar
la suite......
Voila la notice avec les codes pour les vitres....si c'est cela que tu recherches vraiment , je peux te photocopier la notice.....
Laurent
Old 11-19-2002, 05:32 AM
mel79's Avatar
While looking for the instructions to see what the part numbers for the front and rear windows(which are in G-sprue like GTI:s scan shows) I found some construction notes I made while building the kit.
I don't know if these are of any help to you but I'll tell them anyway:
*check out the fit of the rubber parts that are attached to bumpers before you paint the body, as they don't fit too well
*the rear of the rear window shelf(the thing between window and rear seat) can interfere with engine, so you may need to file away a bit off from it
*the engine fit may cause troubles, so be careful
*rear tires are easier to align correctly if you attach the brake & tire combinations to the frame after you have glued the body to the bottom
*front tires may end up being too far in front, so you may have to adjust the suspension a little
*front bumper/spoiler needs adjusting, otherwise it'll end up being too low
-Mikko
Old 11-23-2002, 02:28 PM
Many thanks to all for the efforts, but I really need the Revell partnumbers I don't know where to order Fujimi part in the Benelux, but I know I can order parts with Revell in Germany. In fact they have a rock solid parts service. :sun:
I'll keep on searching
1/12 Tamiya Porsche 935 body help needed usmc1488 WIP - Motorsports 7 09-07-2010 06:11 PM
Porsche 930 Turbo With 3.8TT 700WHP Engine trev0006 Car Videos 0 01-10-2007 01:24 PM
1979 Porsche 930 Turbo possibly best year Da_Maza 911 2 03-09-2005 08:27 PM
1989 Porsche 930 Turbo B. Dean 911 0 07-31-2004 10:22 AM
Porsche GT1 Prototype help needed davidmmz Car Modeling 1 09-09-2002 04:55 PM
