Old 08-13-2007, 12:15 PM
OLDSDAN OLDSDAN is offline
Water Drainage
I have a 2000 Olds Intrigue 3.5. Water is comming in the passenger flooor around the blower motor. It seems to be entering when I am running the AC there is no water drainage for the AC by the weel just inside the passenger compartment. Where can I find any pics of the drainage system for the AC.? I am also figuring that I have to replace the blower motor for rust / oil is now comming out of the bottom of the blower moter too. Is there any recomendations on replacing the blower motor too. THANKS
Old 08-22-2007, 03:39 PM
burijon's Avatar
burijon burijon is offline
Re: Water Drainage
Your drain plug on the passenger side firewall is plugged. It's a rubber L shaped hose. It is fairly difficult to find unless you have a flashlight. I took a stick and poked on the end of mine and got the crud out and then it started draining again.
Changing the fan is straightforward. Remove the glovebox and the plastic shield behind it so you can see what you are doing.
2005 Acura MDX 85k
2004 Acura TSX 96k
Previous 2000 Intrigue head gaskets death
