Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 08-13-2007, 07:20 AM
jsemenko jsemenko is offline
1995 lumina apv
Hi i was wondering if someone can help me i have a 95 lumina van 3.8 and the van hesatation problem i replaced the air filter, and gas filter and i am running out of ideas i have tried differnt gas treatments still it wont go away if some one can help me thanks
Old 08-13-2007, 08:37 AM
LMP's Avatar
LMP LMP is offline
Re: 1995 lumina apv
One easy free step is to clean the Mass AIr Flow (MAF) sensor. Take it out with a few screws and clean the tiny wires with alcohol and care....a few years ago mine did what you described and some dirt had accumulated on the wires.
www.avigex.ca/xport/MAFArea.jpg
www.avigex.ca/xport/maf4864s.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 08-14-2007, 08:29 PM
Android_Gimpy6456's Avatar
Android_Gimpy6456 Android_Gimpy6456 is offline
Re: 1995 lumina apv
Do you have an injector thats bad or, when was the last time you did a tune up?? Just some basic ideas.
There's nothing better than a one wheel peel, espcially when you peel the rubber right OFF.
Old 07-30-2009, 11:46 AM
tomcat0813 tomcat0813 is offline
Re: 1995 lumina apv
If you havent tried this , Try changing the gas line filters.
Old 08-22-2009, 09:36 PM
notsrac notsrac is offline
Re: 1995 lumina apv
Never forget the faulty Throttle Positioning sensor... Your book so tell you how to test it... If I recall? with the key on engine not running measure the voltage at terminal b the voltage should read about .5V... Operate the throttle smoothly to full open and it should not exceed 5volts... if it does or the voltage jumps then replace.. check terminal A to ground for good ground... Check terminal c for 5volt reference signal...
If this is all good it my be a faulty PCM... Had a vehicle that stumble or lagged on take off and it turned out to be the PCM... Get a book and do some testing... 20 dollar book and testing can save you a bunch over plug and play..
