Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-13-2007, 12:17 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Boost doing funny things... boost spike?
Hey all, new problem with the Talon. Once I got the vac lines running right, I was getting some 19psi action which was pretty annoying seeing as how I dont have the fuel system to tackle that. I suspected a faulty BCS and I was right... I just bypassed it all together and she held steady at 10psi. That is until 5k rpms and then she starts going up again. We were doing a 3rd gear pull and once it was spooled, it just pulled pretty constant like it should from 3k on up until we started to sink back into our seats again. I got a bit confused and looked down, she was at 16psi and climbing at like 6k rpms. Testing found that 12psi came at just a tick after 5k. I am suspecting that dinky ass o2 sensor housing (1g, ported pretty good, but its still a 1g) is just not keeping up... what do you guys think?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-13-2007, 12:29 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: Boost doing funny things... boost spike?
Maybe creep? When i first installed my evo3, no matter where i set it, by redline i was at 19 psi. With a tubular O2 housing it does the same thing. When i turned the boost down to 10 psi, it would last maybe until 4500 rpms and just creep back up. I wonder if the O2 housing with the dump tube would work in controlling it. I have the ported exhaust mani, and ported inlet and outlet on the turbo, not sure what else would cause it.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 08-13-2007, 09:17 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
External wastegate FTW
I tried using an internal with my set up and that shit would creep like no other. I personally think they are shitty and would never use one again.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-13-2007, 10:16 AM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
Please let us know what kind of turbo you are using. If it is an EVO or BIG 16g than your in luck. These turbos are known for getting boost creep, it is because the WG flapper is too small. You can fix this by ordering a 34mm wastegate flapper from any of the well known dsm shops. You'll have to take your turbo off and install the larger flapper, but well worth it if you want to controll your boost. Otherwise, just get an external WG.
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
Old 08-13-2007, 04:12 PM
Thor06's Avatar
Jizzed In My Pants
Check sig homie, Big 16g. Thanks for answering the question, I appreciate it all. Its just going to be a fuck it for now kinda deal. Yeah, its a PITA but by next year I should be running atleast that on E85 so I guess I will just have to wait until then. The new turbo (either a EvoIII 16g or a bastard 20g) will get a 34 mm flapper, but I am kinda married to the internal gate as I am going for the stock look.
