Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 08-13-2007, 01:02 AM
BerettaHatred BerettaHatred is offline
93 beretta need help on several issues
I have a 93 beretta with a 3.1 fi. The ignition module,egr valve,crank shaft sensor,computer, one of the coils, and the oil fuel air filters have been replaced. But It's still not running very good. It usually takes several cranks to start up. At times when i have to accelerate the car hard it dies. I am not sure what else to replace. I figured out that most of the problems are from the Torque converter selonoid so i unplugged it and the amount of dieing went down a lot. I now need to know how to replace it. Any and all help is appreciated thank you very much.
Old 08-14-2007, 10:42 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 93 beretta need help on several issues
Welcome to AF
Do you have any check engine light on, if so, what codes are stored.
Replacing the TCC solenoid is difficult due to it's location. It is under the side cover of the transaxle and requires dropping the engine/trans down to clear the subframe rail.
Outside of what you already replaced, the TPS (Throttle Position Sensor), IAC (Idle Air Control) valve and FPR (fuel pressure regulator) are all causes of your symptoms.
Since it acts up mostly when you try to accelerate, I would suspect the TPS and FPR first, as the IAC only affects idle/part throttle operation.
The TPS you can test by unplugging it, hooking a digital or analog multimeter set to ohms to it and move it through it's range of motion. The change in resistance should be smooth and linear with no gaps, or sudden big jumps.
Check the FPR for fuel in the vacuum line (this would indicate a ruptured diaphram that is leaking). Also check fuel pressure with a guage hooked up at the schrader valve (should be 41-44psi, key on/engine off) and should drop 3-7 psi engine running with the vacuum hooked up. Unhook the vacuum line to the FPR, and fuel pressure should increase back up to near original Key on/engine off readings. Good luck!
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-19-2007, 12:32 PM
No there is no check engine light on. I have tried several times and have found no trouble codes. I will try the tests you recomended. Thank you very much for the input.
Old 08-20-2007, 06:09 PM
It seems to be getting worse lately. It is especially bad when the motor is warm. Does this make a difference that most of the problems happen when the car is warm?
Old 09-18-2007, 12:15 PM
Okay, Here I am back again. Tps, Iac, plugs/plug wires, is what I replaced this time. Still not running good. About a month ago i was pulling roughly 27 miles to the gallon. I ran the numbers and my last tank of gas I averaged 18 miles to the gallon. Would anyone have a clue of what is going on? Thanks
Old 09-19-2007, 07:07 AM
richtazz's Avatar
HAve you checked fuel pressure with a guage? It should read 41-44psi, key on/engine off, then drop 3-7psi when the engine is started and the vacuum is still hooked up. If you pull the vacuum to the FPR with the car running, pressure should jump back up to near key on/engine off readings.
Old 10-06-2007, 10:13 AM
loosenut74's Avatar
loosenut74 loosenut74 is offline
Send a message via Yahoo to loosenut74
check your compression yet?...
Old 10-24-2007, 12:31 PM
No, Haven't gotten to it yet..
Old 10-24-2007, 12:58 PM
flyguy123 flyguy123 is offline
Did you look for vacuum leaks? I assume you replaced plugs and wires already. Have you looked at your spark to see what it looks like when its acting up?
Old 10-24-2007, 08:14 PM
loosenut74's Avatar
also as said before check your fuel pressure...
Old 11-11-2007, 08:07 PM
Yes I looked for vacume leaks. Checked the fuel pressure finally it is good. What next? All I can think of for my gas mileage to drop from 28 to 17 mtg is that i have a coil out.
Old 11-12-2007, 07:48 AM
It could be your coil but you need to look and see what kind of spark your getting before replacing the coil pack.
Old 11-12-2007, 04:56 PM
Styluss Styluss is offline
Check your PCV valve! I had a stalling issue and i replaced every sensor on the engine before I replaced the PCV valve, which was the issue. Plus it is sooo easy to do and the part is cheap.
As for your TCC replacement, see here:
http://www.v6z24.com/howto/tcc
Ryan Haenny
1989 Chevrolet Beretta Euro GTU
Lakewood, CO.
Old 11-12-2007, 10:27 PM
Where is the Pcv valve located?
Old 11-13-2007, 12:01 PM
The PCV valve is on the back of the engine. There is a plastic hose that goes to it. Simply remove the hose, and then the PVC vlave will wiggle out of its housing easily. Just slap another on in there and go!
I might be able to get a pic later if it will help.
Ryan Haenny
Lakewood, CO.
