Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-12-2007, 07:26 PM
hardrock121 hardrock121 is offline
Cool Olds 88 Questions
I have a 93 olds 88 with 85K miles. Was my fathers car and I'm trying to address10K mikes of negelct.
Questions:
1) Where do I locate the ALDL connector? I understand you jump "A" and "B" terminals for readout---where does it display?
2) One of the tranny cooler lines is leaking where the 5/16" rubber hose connects to the cooler. I've replaced both hoses but still have a drip at the connection. Suggestions? Is there something that could be creating high pressure on the line?
Tks
Old 08-12-2007, 07:49 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Olds 88 Questions
When you jump the A&B connectors you watch the check engine light to flash. The first series of flashes (they go in a series of 3 for each stored code)will be a "12". That's one flash followed by 2 flashes. That indicates the system is in the diagnostic mode.After the code 12 flashes there will be a pause (5 to 6 seconds ) before any other stored codes are presented.Then the other codes will show ( i.e. a code 25 will be two flashes followed by five flashes.) If there are no other codes present it will flash a code 12 again.
Here is a picture of the ALDL connector:
It can be found under the dash in the area under the radio or a little towards the left.
On the issue of the cooler line is it possible to replace the leaking connection with a compression fitting? They tend to handle pressure better than a simple hose clamp if that what is currently there.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
