Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 09-18-2001, 04:37 PM
Jeff M Jeff M is offline
Question Service Engine Light is O??
Hi All,
I was changing the oil in my buddies 98 Maxima and he decided to drop in a new air filter. After I was done he said he started the car and the service engine light was on. I had him pop the hood and noticed he had not reconnected the MAF sensor attatch to the airbox. I connected it and he started the car and and the light was still on. Having owned a 95 Z I figured he should disconnect the battery for about 10 minutes and that should reset the ECU and the light would disappear...no dice. Any suggestions on how to get the light off??
Thanks,
Jeff
94MkivTT
Old 09-18-2001, 04:47 PM
black019 black019 is offline
you probably have to reset the ecu manually
High Octane Boards - Members Wanted
http://www.mnbmotorsports.com/forum
Old 09-18-2001, 06:14 PM
Ravq Ravq is offline
Here you go. It's at the bottom of the page but might as well read the codes it stored to be sure it really was the MAFS.
http://vbxmaxima.8m.com/ecu.html
you can translate the code using the following:http://vbxmaxima.8m.com/ecudecoder.html
Stillen kit & grill, Stillen Type II spoiler, KYB AGX/Progress, 19x8.5 ADRs w/Toyo Proxes FZ4s, ...........
Old 09-18-2001, 06:15 PM
WaarrEagle WaarrEagle is offline
Send a message via ICQ to WaarrEagle Send a message via AIM to WaarrEagle
Yup, the same thing happened to me. I forgot to reconnect the sensor and got the check engine light. I had to manually reset it and it turned off.
Old 09-18-2001, 06:34 PM
thanks everyone!!
Jeff
Old 09-18-2001, 11:57 PM
Y2KevSE's Avatar
Y2KevSE Y2KevSE is offline
Send a message via AIM to Y2KevSE
You need to leave the battery disconnected for a longer period. Try a few hours or so.
Maxima.org Admin
\Turbocharged...
Turbonetics ball-bearing T4/T04E 60 trim with polished compressor housing
NorCal Maximas CarDomain Site
CarDomain Site
Featured on NissanPerformanceMag.com
