Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-12-2007, 06:03 PM
zeanimal2001 zeanimal2001 is offline
ECU the problem?
Hey guys...to break it all down my 93' GS wouldnt start because the Fuel Relay wasnt getting voltage...It turns out it gets voltage sometimes and other times it doesnt...I had to tape the relay down to get it to drive most of the time...so i figured it was the ECU because it worked intermitently and moving wires didnt result in a change. Now my Idle RPM is low at around 500 and my check engine light is on and it drives REALLY slow and sluggish...Im hoping this will be solved when the new ECU comes...Any input?
ALSO: Is there anyway to get the code for the CEL without buying a OBD1 scanner? Autozone and ADA both dont have a scanner for my car... :-(
Thanks Everyone!
