Go Back   Automotive Forums Car Chat > MG > MGB
Old 08-12-2007, 05:53 PM
MGvol MGvol is offline
Question 77 MGB steering lock
I need to replace the original steering lock and ignition switch. The original lock doesn't appear to have any screws on it. Instead it looks like it has to rivets, one on either side of the steering column, that hold it on. Do I have to drill out these rivets or is there another way to get the steering lock off?
Thanks.
Old 08-13-2007, 05:32 AM
Flash75 Flash75 is offline
AF - Advisor
Re: 77 MGB steering lock
They are not rivets, they are break away screws, they are tightened until the head breaks off. Use a Dermal tool with a cutting disc to slot the screw and they can be removed with a big screwdriver or an impact driver.
Clifton
Old 08-13-2007, 09:14 AM
Clifton,
Thank you for the quick reply. That's the best news I've had in a while. I was not looking forward to drilling out those rivets.
Thanks again,
John
Old 01-10-2008, 11:16 PM
Bluetick Bluetick is offline
Thanks.
I had a '74 B and thieves broe into it & ruined the switch trying to jimmy it. The switch is secured by bolts that have torque removeable heads. The hex heads wring off when you tighten them down thereby creating a secure / locked steering column. I changed it myself by taking a small cold chizel and unscrewed the headless bolts little-by-little. It took about 1/2 day to do this as it is tedious work. You have to create an indentation in the bolts that will hold up under tapping of the chizel with a hammer. You may be able to use a flat head screwdriver to tap & back the bolts out once you have made the dents with the chizel. Good luck. It ain't easy but with patience you can get 'er done!
Old 01-11-2008, 09:18 AM
[quote=Flash75]They are not rivets, they are break away screws, they are tightened until the head breaks off. Use a Dermal tool with a cutting disc to slot the screw and they can be removed with a big screwdriver or an impact driver.
Clifton[/quote
I like the idea of the Dremal tool. I don't think they existed when I had my problem. Either way - beats drilling which can be risky. ]
