Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 08-12-2007, 04:40 PM
cmyers2002 cmyers2002 is offline
1993 del sol trunk problem
Hello . I just bought a 1003 del sol and the trunk closes only to the first latch . you can't open it with out key , but it doesn't close all the way . it has a 1/2 inch gap between lid and body . Can anyone tell me how to get it to close all the way . Thanks in advance . [email protected]
Old 08-23-2007, 09:18 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: 1993 del sol trunk problem
I didnt know they even had cars in 1003... lol.. sory i had to...
there should only be one "latch" for the trunk, it sounds like its WAY out of adjustment. try adjusting it to bring it down more.
Old 12-06-2007, 03:05 PM
pistolpeterson pistolpeterson is offline
My 1995 del sol has a trunk problem too. When you pull the lever in the car, it will unlatch as you would expect, but it doesn't pop open. Thus when you get out of the car to lift the lid, it has relocked. You can only open it by turning the key to the trunk and lifting the lid. It doesn't pop up when you turn the key. I'm not sure why. Maybe the trunk lid supports? (struts).
Old 12-15-2007, 05:44 AM
sbiddle sbiddle is offline
I have the same issue with my '96. Does anyone know how to make the trunk jump up?
Old 01-02-2008, 12:36 AM
wyattdelsol wyattdelsol is offline
Send a message via MSN to wyattdelsol
I have a '93 without the interior trunk latch. I have to open my trunk with the key but unless I pull it up when I turn the key, it won't open. It's a pain in the butt! But my '95 has the interior latch and it opens perfectly. Help us all out!
~wyattdelsol
Old 01-09-2008, 07:16 AM
I'm going to replace my trunk lid supports and see if that fixes the trunk lifting problem. I'll let you know if it is a fix.
Old 01-09-2008, 10:00 PM
Thanks man. It drove me crazy tonight having to open the trunk.
Old 01-15-2008, 08:55 PM
hermanssol hermanssol is offline
I just fixed my trunk today. all you have to do is adjust the two rubber knobs at each corner of your trunk lid. each corner has one, and they have threads on them like a screw. just unscrew them til the lid is able to pop up on its own when you use the key or the latch inside the car. good luck.
Old 01-15-2008, 09:54 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
its all in the tension of those rubber bumpers that where mentioned more tension equals higher bounce when you pull latch release
