Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-12-2007, 04:44 PM
stimfil stimfil is offline
99 I30 stalling, HELP?
The Vechile Runs Great While In Park, I Can Hold The Brake In Drive And Press The Gas Pedal Runs Fine. No Instrument Light On. Once The Vechile Gets Moving And I Press The Gas Pedal It Stalls Out, Rpm Goes From 1100 And Continue To Drop Till The Engine Dies. Throttle Body Is Clean, Maybe An Easy Fix Before I Take It To A Shop. Friends Say Fuel System Problem But It Starts Up Fine So Its Getting Gas. What Might Be Causing This?
Old 08-13-2007, 01:26 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 99 I30 stalling, HELP?
Smtg happens when engine moves related to chassis. (Is there any cold/warm relation?)
- Ripped intake tube; intermittent air leaks (after MAF). Take out, Inspect...
- Ctrl Wirings, connectors broken.
Quick tst by disconnecting MAF connector. Any change?
Old 08-13-2007, 09:46 AM
no sign of air leaks, all conectors appear to be intact and in good shape.
however MAF is what?
and thank you for your 1st reply.
Old 08-13-2007, 12:46 PM
MassAirFlow sensor, the 'box' after intake filter (one connector). Taking its connector out drops MAF problems out of pic (2200 rpm ceiling).
The intake 'hose' flex part can have hidden cuts, inspect carefully.
Measure actual fuel pressure. Hosing may have kinks, blocks, and/or pump is semi-re-tired...
Do some service on connectors which may move when wiring moves, check how http://www.cardomain.com/ride/748507/14
Some MAF related links on this page http://www.cardomain.com/ride/748507/9
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
