Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-12-2007, 02:41 PM
mtech mtech is offline
00 CVPI Partial Power Loss
Lost power,On only some circuts including pcm,dash gauges,windows,brake lights.Working are headlamps,interior lighting,blower high only.Have car in pieces checking wiring,batt. junction box all has power,Central junction box has limited power as does the ignition switch(which tested good ).Just wondering if any known trouble spot's in harness or other area's possibly succeptable to cause this problem,pulled into drive and it died,been searching ever since. Simple as computer failure ? If relay to pcm is activated thru test light can get into pcm w/scanner and it has abnormal reading's in my opinion but does show parameters,I have limited spec's access to compare to for known good. Any ,all help appreciated, Thanks
Old 08-12-2007, 06:06 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 00 CVPI Partial Power Loss
Look on the drivers side under thrbattery. They are bad about wires breaking where they make the bends going from the Power Distribution to the tray inside the front bumper cover. Look for a brown wire.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-13-2007, 01:35 PM
Well THANK YOU very much,raised it up on hoist and the first area there I opened up I seen green corrosion and the brown wire pulled apart,spliced it and all is working again,your direction to area was right on.
Most of my experience is with GM,this is the first Ford product I've owned in about 25 year's,the last was an Indiana State Police car in '82
Thank's again
Old 08-13-2007, 03:16 PM
way2old's Avatar
TOKEN HILLBILLY
Thanks for the fixed post. Come on back if you need us.
