Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-12-2007, 02:09 PM
GSXBMX GSXBMX is offline
Send a message via AIM to GSXBMX Send a message via Yahoo to GSXBMX
'84 Mustang starting problems...
i have a 1984 mustang with the carburated 5.0 v8 in it.last night i rolled down the windows and went to start the car and got nothng...wouldnt even turn overattery tested.the local auto shop said it was fried so i got a new one and installed it immediatley...still nothing!even with a fresh battery it wont turn over,i dont get power to anything in the dash or interior of the car.what could this be?a fuse problem?and if so,where are the main fuses located in this car...i cannot locate the fuse box...or what else mnight be the cause of this?any insight is greatly appreciated
Old 08-12-2007, 02:18 PM
2001jettavr6 2001jettavr6 is offline
Re: '84 Mustang starting problems...
most of the time your fuses are located under the steering wheel or to the side of it when you open the door, and it could be the ingnition.
Old 08-14-2007, 09:29 AM
1995gtvortech 1995gtvortech is offline
Try to take a large guage wire like a jumper cable hook it up to the negitive then the other end of the same wire to a ground. this bypasses the groung wire and eliminates that. do you hear a click noise anywhere?
