Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 08-12-2007, 12:36 AM
BarneyW1 BarneyW1 is offline
98 Mistique OBDII code 1131
I have a OBDII code of 1131 Lack of HO2S1 Switches-Lean (Bank 1 sensor 1). The check engine lite comes and goes. This is a 4 cylinder engine in the Mistique. Any good Ideas as where to check? MAF sensor was just cleaned. I'm getting poor gas mileage too, around 19MPG VS: 28MPG not too long ago.
Old 08-12-2007, 02:00 AM
2001jettavr6 2001jettavr6 is offline
Re: 98 Mistique OBDII code 1131
does your car smell like rotten eggs? or hear a slight rattle under the car? when the engine like comes on its usually emissions. signs of a catalytic converter going bad is gas mileage and your engine light coming on/ flashing while driving
Old 08-14-2007, 08:20 PM
2001jettavr6 ...nope no smells or loss of power....Cat is not rattling and doesn't seem to be plugged. Does anyone know what sensors would be involved in this problem?
Old 08-15-2007, 11:44 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Its the upstream 02 sensor. If your running lean, I would guess youve got an intake leak somewhere. I would rule the cat out.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
