Old 08-12-2007, 12:12 AM
littlewillie littlewillie is offline
2003 Instrument Cluster Un-Plug / Plug
Hey Guys,
I've read about some of the clusters going out (not working) & that un-plugging & re-plugging the wiring harness will sometimes fix this problem. Are there more than one connectors & do you have to remove the cluster before you can un-plug it. Basically I'm asking for instructions on how to un-plug the instrument cluster. The lights work on it but none of the gagues do.
Thanks,
Willie
Old 08-12-2007, 12:41 AM
FiTxAg04's Avatar
FiTxAg04 FiTxAg04 is offline
Re: 2003 Instrument Cluster Un-Plug / Plug
You have to first pop the dash bezel off, which just snaps out. Once this is out, there are 4 screws (one on each corner) of the instrument cluster that have to be removed. Once these are out, the cluster just slides out and the wiring harnes can then be accessed on the back of the cluster.
Good luck with this. If it doesn't work, there are a couple of guys on ebay that will repair your cluster if you send it in. Cost to replace all the motors is around $150... you just have to live for a couple of days without your gauges. If you have a gps, you can use it when driving to tell you your speed.
2004 Chevy z71
BF Goodrich T/A KO 285/75/16s. Flowmaster 40 Series exhaust. K&N intake. Stull billet grille. F-150 torsion bar index keys. 800w stereo system.
Old 08-12-2007, 10:55 PM
FiTxAg04. Thanks for the info. The gauges started back working today without anything being done. Loose connection????? Maybe. If it happens again, I'll pull the cluster & check the wire connection. If it happens 2 more times, I’ll pull it & have it looked at.
Willie
Old 08-13-2007, 02:19 AM
brentcausey brentcausey is offline
Willie,
I had this happen to a buddy of mine. He unhooked his battery overnight and re-connected it the next morning. Fixed all of his problems. Brent
Old 08-13-2007, 11:57 PM
brentcausey, Thanks for your reply. As I said earlier everything is working as it should. Started back working on its own. If it happens again, I'll try your method.
Willie
