Go Back   Automotive Forums .com Car Chat > Mercury > Villager
Old 08-12-2007, 12:09 AM   #1
woodstock_62
Question 99 mercury villager
help!! i have a mercury villager the check engine light came on after that it started losing power it wont go over 40 then wont go at all it keeps shuting off. took it to parts store got diagnostic test said to replace knock sensor. could knock sensor cause that problem?
woodstock_62 is offline   Reply With Quote
Old 08-14-2007, 06:21 AM   #2
IH8SPM
IH8SPM's Avatar
Re: 99 mercury villager
NO NO NO NO
Did I make it clear yet. Search for knock sensor on this forum and read. You have internal problem and the knock sensor is the band aid and thats it. It is an indicator of a problem not the cause in any way.
IH8SPM is offline   Reply With Quote
Old 08-14-2007, 11:16 PM   #3
QuestOverload
Originally Posted by IH8SPM
NO NO NO NO
I totally agree. The *** knock sensor has been bad on every one I've ever owned, and at $600+ or almost pulling the motor to change it, they've stayed that way, and it hasn't hurt anything, and it never will, because the knock sensor only kicks in when the car is knocking and I doubt any of these vans have ever knocked.
1996 Villager (newest, 80k miles, CLEAN!!)
1995 Villager 147k (new driver, bad lifters, 24.5mpg)
1993 Mercury Villager 156k (fair game for parts)
1993 Mercury Pillager 178k (Pillaged 4 parts)
1995 Nissan Quest 194k (driver)
1995 Mercury Villager (sold 181k)
1996 Mercury Villager (sold 134k)
1995 Mercury Villager (sold @ 184k)
1993 Nissan Quest (sold @ 137k)
1998 Mercury Villager (sold @ 90k)
QuestOverload is offline   Reply With Quote
Old 08-16-2007, 12:09 AM   #4
Bob Mayo
I agree to NOT change the knock sensor. I am willing to bet that there were other codes logged as well. You need to find out what the other codes are and the code numbers such as P0325 (Knock Sensor). The other code(s) will probably point to the correct problem area.
Bob Mayo is offline   Reply With Quote
Old 11-18-2007, 12:32 AM   #5
davester
had a very similar problem with my 94. knock sensor codes six seven times. Its true, the knock sensor indicates other problems. Mine had the same symtoms as yours. I had changed alot of parts at the time for nothing. After 1 month of sweating, turned out to be the distributer. Not the cap, but the actual distributer. You can get one at any bone yard for around 75 bucks.
davester is offline   Reply With Quote
