Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 08-11-2007, 08:23 PM
Calgary ZR2 Calgary ZR2 is offline
Where did you mount your MSD?
I currently have my MSD mounted above the distributor. However I am finding it getting to hot in that location. I have already had to replace one due to heat, and I live in Calgary, not the warmest climate city.
Where are some of the locations you have mounted yours?
Old 08-12-2007, 10:11 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Where did you mount your MSD?
another place to put it under the hood where it would still be accessable is on top of the blower motor housing.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 09-19-2007, 06:39 PM
Blazer SS Blazer SS is offline
I placed mine inside of the center console between the seats. I put a vent above and below it. I mounted it vertical. And left enough room so that I can do any adjustments by removing the top vent. You would have to take out the center console . And mount it to the metal support. It will also act as a heat sink. there is enough room between the support and the plastic for it to fit there. You can pull out the bin and still not see it there. I forgot to mention that it is a Crane IS6, But they have about the same dimensions.
