Old 08-11-2007, 08:19 PM
Lilbubblebutt Lilbubblebutt is offline
Unhappy 1981 Chevy 1500 Doesn't Fire!!!
I HAVE A '81 CHEVY 1/2 TON THAT WON'T FIRE. I HAVE CHANGED THE IGNITION MODULE, AND THE COIL AND I STILL HAVE NO FIRE. I NEED HELP!!! ANY SUGGESTIONS?!!?
Old 08-11-2007, 08:47 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1981 Chevy 1500 Doesn't Fire!!!
suggestions... I'd start with some lower case 12 pt. letters, perhaps black in color, and only posting once.
Doesn't fire as in no spark, or a crank no start?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 08-12-2007, 05:43 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Do you have power to the ignition coil?
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 08-13-2007, 09:39 PM
Unhappy Re: 1981 Chevy 1500 Doesn't Fire!!!
how do i check to see if the coil is getting power????
Old 08-13-2007, 10:55 PM
horse482's Avatar
AF -Advisor
Voltmeter, red to power, black to ground. Should have 12.6v. Also have you checked the timing?
NO 4 N JUNK
Old 08-13-2007, 11:34 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The magnetic reluctor/pickup assembly inside the distributor may be tango-uniform. You can use a voltmeter to check it, too. You will have to pull the two-wire lead from the module (this side of the module will only have two leads, as opposed to 3 or 4 with the computer connection). Set the voltmeter to the 10k OHM scale (resistance check), and touch each terminal to one of the probes. You want to see the needle near the 0-ohm mark - if the needle doesn't move (infinite resistance) or moves only partially, suspect the pickup. To replace it however, one will need to remove the distributor and press out (you can use a hammer and a punch) the roll pin that holds the gear on - and then pull the shaft up and out through the top. Have a new roll pin handy when you put it back together, and make sure it's flush with the gear once installed - nothing should stick out.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-14-2007, 11:15 AM
there no power to the coil what can it be???? im so confused
Old 08-14-2007, 11:48 PM
horse482's Avatar
AF -Advisor
I would look in to getting a wiring diagram. I cannot remember if the hot wire on those trucks is a constant hot or key on hot. If it is a constant hot try running a jumper wire from the + on the bat to the bat terminal on the coil.
NO 4 N JUNK
