Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-11-2007, 04:37 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
92 camaro help please
i have a 92 camaro rs its a 305. the car was runing good and all that but i had it stall on me a couple of times and now it doesnt start at all it just cranks and cranks.
im thinking my fuel pump died is there a way to check it and what else should i look for. the car only has 100k miles on it.
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 08-11-2007, 06:15 PM
CreepingDeath94 CreepingDeath94 is offline
Re: 92 camaro help please
You can check the fuel pressure if you have a gauge that you can plug into the fuel rail. I think you should be somewhere in the neighborhood of 30 psi, but I just pulled that number out my butt. I do know, you'll want to check it right after you turn the key to see if it builds, than crank it and see where it is. Will it run on starter fluid, like carb. cleaner or anything? Usually a cheap quick way to see if it is just not getting fuel...
