Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-11-2007, 02:45 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Car loves to run HOTT
Ok guys lets see if you can help me out. It has been a really hot summer here and yesterday I had to go see my grandma in the hospital. It was about an hour away and she wasn't doing to well so I was in a hurry. I was on the interstate and no matter what speed I was going the car wanted to run a little warm, only about 2/3 on the temp gauge but still more than normal. Even at idle it would creep up on the gauge. I finally turned the heater on and the temps dropped back down to normal and I rode the rest of the way there like that. So it was about 105 degrees and Im riding with the FU*KIN heater on!! This sucks so bad. Then today when I was coming home the car ran fine until the AC was cut on then it wanted to run hot again.
I took out the AC fan for the turbo but that should effect anything at 80mph. I'm guessing my FMIC is causing all of these problems but I still would like to fix them a little. I just change the coolant to and added water wetter hoping that would help. Should I change the thermostat to something lower just for the summer? Thanks
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-11-2007, 03:13 PM
steviek's Avatar
steviek steviek is offline
Re: Car loves to run HOTT
I have been recomended to get a 170 thermostat. Water wetter plust more water then coolant mix also helps. You can also hotwire the fans to keep the heat out of the rad. You can try and dam the air straight through your fmic to your rad. You should also have the intake dammed off from the engine bay. And you should put your heat shield back on
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 08-11-2007, 03:20 PM
Holset powered 420a
Ha, heat shield, are you refering to that other tread?? I would put a heat shield back on except I dont remember seeing one for a 420aT!!
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-11-2007, 04:23 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
I know exactly what you're going through. It was 107 here yesterday. I don't even drive the clipse when its that hot. But I have the same problem with the car running hot.
I tried the water wetter and wiring the stock fans, with the heat shield installed and that didn't help at all. This week im going to flush out the cooling system, and add some water wetter and fresh coolant and water mix. Probably 60:40 water to coolant. I also have 2 12 inch slim line fans on order that are supposed to flow upwards of 1200 cfm each. If that doesn't work i guess i will be buying a fluidyne radiator. What I dont get is my buddy's gst has a bigger FMIC than i do with no ducting and he doesn't run hot.
If you figure it out let me know.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 08-11-2007, 04:52 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Try blowing out the radiator with an air compressor. You'd be surprised how much shit gets stuck in between the fins and restricts airflow. Watch out though, you might want a dust mask right away.
95 Talon TSI AWD
97 Eclipse GST
Old 08-11-2007, 06:55 PM
steviek's Avatar
make your own thats what I did. I bought 7 dollars worth of aluminum and made an intake dam and a heat shield out of it. Best 7 bucks I ever spent.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 08-12-2007, 12:32 AM
Holset powered 420a
Im actually workin on a heat shield now. I am ordering a slim fan so I will have to now. And maybe try a 180 thermostat. If that doesn't work I might wire an all time fan up or something.
98 Eclipse GS Turbo
2001 BMW 325i - DD
