Old 08-11-2007, 02:25 PM
Kebo33 Kebo33 is offline
Question 1999 Blazer LT and lower ball joints? Help, Please!
Well I read everything I could find on here about replacing the ball joints. The top one went without fuss.....I had to air chisel the rivets off, but then I can't find any rivets in the lower ones. Does this mean that they are pressed in only? If so, how do I get them out? Please don't tell me that I have to remove the lower A-frame arm and take it some where to be pressed out. And I take it that they should still be pressed out of the bottom, correct?
Old 08-11-2007, 09:53 PM
Re: 1999 Blazer LT and lower ball joints? Help, Please!
Well I bought the Harbour freight ball joint remover. Hmmm, lacks a lot to be desired, but I did get one side out after hours of trial and error. I will press the new one in tomorrow and then start on the passenger side. Yay, fun.
Old 08-12-2007, 03:41 PM
drdd's Avatar
drdd drdd is offline
A picklefork won't do the trick?
Old 08-12-2007, 05:36 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Both the top and lower ball joints are rivited on from the factory, or have a nut and bolt if the factory ones were replaced, they were not pressed on. A '99 with original ball joints....thats pretty good considering ball joints are a common part for replacement.
Old 08-13-2007, 06:24 AM
Wink Re: 1999 Blazer LT and lower ball joints? Help, Please!
Well, I will have to beg to differ........the bottoms on my '99 LT are pressed in. I finally got them out and the new ones pressed in. The tops are riveted in and were fairly easy to get out with the aid of an air chisel. I broke the c-clamp press that I bought at Harbour Freight. I had to go and rent one from Advanced. That made all the difference.
