Old 08-11-2007, 02:23 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Stoopid Fuel Filter QD!?!?
Hey guys, i was under the car for 20 minutes figuring out how the hell you get the green clip off the quick disconnect side of the fuel filter?? I already squeezed the clip and it lifts up or whatever but it still has a tight grip on the filter body. I played with it for awhile then decided to screw it because i didnt want to break it! I did my 1996 fine, but its either 98+ cuz of revised engine, or its the 2000+s, they changed the location and the QD. Anyone know the easiest way to get it off? By flipping the green lock up does that mean its unlocked or do you need to pull it off completely somehow? I cant slide the QD over the lip on the fuel filter body.
Any help is greatly appreciated!
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 08-11-2007, 04:08 PM
Jmrec100's Avatar
Jmrec100 Jmrec100 is offline
Re: Stoopid Fuel Filter QD!?!?
I sympathize. I went thru the same thing. What is with these screwball designs. Mine is located at the rear and tucked under "things". I ended up getting an oil change and told them to change it out for me. Cost me $10 for what I know was a simple job. I need the car running asap to get to work. Its a goofy clamp on one side. I'll look at the old one and see if I can help. Its a simple trick to it but the Haynes and Chilton's didn't explain it. I'd be interested to if anyone can explain it.
Old 08-11-2007, 06:56 PM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
when you pop that green tab out take both sides of the clamp and push it back thru the other side... then the filter should pull right out
