Old 08-11-2007, 03:13 PM
mbazid mbazid is offline
Battery light?
Hi there thanks for the advice. I went and had the battery checkd and sure enough it was no good. I installed it but the battery light comes on. Actually it comes on for a few minutes than goes off for a few than comes back. If it were the altinator wouldnt the battery drain rather quickly? Or wouldnt the altinator light come on? I was told at the autoparts store that if it were the cable I would smaell burning platic. Is that true?
I appriciate your help
Old 08-12-2007, 09:44 AM
wiswind wiswind is offline
Re: Battery light?
You want to clean all the cables, and battery terminal connections.
You don't need to be smelling a burning smell for them to be bad.
It would be worthwhile to have the alternator load tested to see if it is weak.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 08-12-2007, 09:55 AM
Rotorman Rotorman is offline
Re: Battery light?
Good morning mbazid, I would carefully check your serpentine belt and tensioner. There should be no slack in the the lenght of the belt. I hope this gets you on the right track.
Rotorman
