Old 08-11-2007, 02:20 AM
simplexveritas simplexveritas is offline
hid conversion triggers bulb out/electrical notice
hi group, i'd like to know if anyone has a done a hid conversion where there is a bulb out warning or some electrical issue when wired without a harness. i'm thinking of picking up this kit for the warranty, but they don't include resistors which i understand traditionally can help. i've heard some say it can be a matter of getting a wiring harness and not directly plugging in. but something tells me it's not a hid wiring harness issue -- or is it?
Old 08-12-2007, 02:36 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: hid conversion triggers bulb out/electrical notice
you really need an aftermarket wiring harness for the HIDs because they draw more power at startup than your average halogen bulbs, 85W for HID compared to 55-65W for halogen.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
