Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 08-10-2007, 11:40 PM
vandok13's Avatar
vandok13 vandok13 is offline
Oil
I was doing some trails and i rolled my 1988 4runner onto the roof. It was on the roof for about 30 minutes, i used a come along to get it back on all fours. I let it sit for prolly 2 hours then i started it but now it burns oil. It wont stop burning oil and before the accident it was fine, any ideas. Could it just be the valve seals or something?
Old 08-13-2007, 11:26 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Oil
It could be that you have some oil in the cylinders, and possibly in the intake and exhaust manifolds. It seems to me that it will burn off eventually. You might try removing and cleaning out the intake manifold, and changing the plugs. The intake manifold would take the longest to get all of the oil out. Not much you can do about the exhaust system if there is alot in there. Should burn off. Might be bad for your cat converter.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-14-2007, 10:47 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Oil
It's unlikely you damaged the engine. It should burn off as above.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
