Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-10-2007, 11:35 PM
gio6661 gio6661 is offline
Convert 2 digital climate control (Cool!)
I own a 96 2 door supreme and i wanted 2 know if i own a climate control with the knobs how can i convert to the digital 1 that reads the ext. temp and what wires go where(extra wires also)??.
ps....where is the sensor that reads that temp?
Old 08-11-2007, 10:43 PM
3100MPFI 3100MPFI is offline
Send a message via AIM to 3100MPFI Send a message via MSN to 3100MPFI
Re: Convert 2 digital climate control (Cool!)
the sensor that reads the outside temp is located on the exterior, behind the front bumper. There is a metal support that goes from the hood latch down to the radiator support. That is where the outside temp sensor is located.
To do this swap properly, you have to remove the entire dash out of the car. I did this swap to my 1988 Cutlass Supreme (almost the exact same swap as far as the work goes). You will have to do more work to your car than I had to do to mine.
If you want to read the procedure for the 1988-1994 interiors, I did a writeup over on wbodysource. You will have to do the same things, but in your car, you also have to remove the entire interior air duct and swap it out with the dual zone setup.
Here is a link to the swap.
Just so you know, this swap is NOT for the faint of heart.
