Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-10-2007, 09:17 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
1g/2g Transmission help!!!!
I have a 1996 Eclipse GST with a 6 bolt swap. I am tired of spining my tires in 1st,2nd, and 3rd. I bought myself a 1995 Eagle Talon AWD shell. Now...all I need is a AWD transmission/clutch/flywheel. I was wondering since I have a 6 bolt swap is it possible to use a 1g transmission in my 2g talon with the 6 bolt outta the gst? Would I need to fab anything or would it work no problem?
Let me know!!!!
Thanks
Ben M
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 08-10-2007, 09:21 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 1g/2g Transmission help!!!!
I don't believe so. The 1g tranny mount is on the motor, where the 2g mount is on the car (or vice-versa), so you'd need to either so some fabbing, or the other option is to put the 1g tranny into the 2g tranny "shell", if that makes any sense. And yes, it is possible, very tedious, but possible. It's what I'll be doing to get my 1g TRE into my 2g awd tsi.
95 Talon TSI AWD
97 Eclipse GST
Old 08-10-2007, 09:27 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
For fucks sake does anyone know how to use the subforums anymore?
As far as your problem, the 6 bolt and 7 bolt engines used different setups... the 6 bolt had 3 mounts on the block and one on the tranny. The 7 bolt is the opposite, 3 on tranny and 1 on block. I've heard that you can use the 2g tranny in a 6 bolt car, but yes, a 1g tranny will work. I've heard that 2g trannies are strong stock so you might consider one of those, but as strapped as you are you might want to just shell out for a shep 1g tranny. As far as the fabbing goes, it shouldnt be much different than doing the 6 bolt swap in the GST.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
