Old 08-10-2007, 07:53 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Quick A/C Q - 2006 Silverado 1500
I'm asking this on behalf of a good friend who has a 2006 Silverado. The fan for his A/C fails to run if the switch is in the 4 or 5 position. I might consider it to be a resistor array, but it also could be a relay. It could also be the switch! For the more enlightened with these trucks, what would be the best place to start?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-10-2007, 09:56 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Quick A/C Q - 2006 Silverado 1500
Check Resister block first if it has one.
Is it auto ac controls or manual?
MT
MT
Old 08-10-2007, 10:25 PM
silicon212's Avatar
Confoundingly Lucid
MT
It's manual, it has the dual vertical sliders.
Old 08-12-2007, 12:50 AM
silicon212's Avatar
Confoundingly Lucid
Turned out to be the resistor block, after all. Thanks MT.
Old 08-12-2007, 08:12 AM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back how it went.
Glad you found the problem and got it fixed.
MT
MT
Old 08-14-2007, 04:31 AM
02sil'ado4.8 02sil'ado4.8 is offline
my truck does just the opposite. It just started happening. The Compressor turns on when I turn the switch, but doesn't blow until I go to speed 4 or 5. what did you do to the resistor block and how can I fix my problem?
2002 Silverado 4.8 LS Shortbed - Mods-K&N air filter
Old 08-14-2007, 11:43 AM
silicon212's Avatar
Confoundingly Lucid
I replaced the resistor block with a new one, which I obtained from Thorobred Chevrolet for about $40. It's located in the blower housing under the dash, near the motor (it's held in place with two bolts). There is a plug with about 6-8 wires that plugs into it, and there's a black and red wire that come out of it and plug into the blower motor itself.
Old 08-14-2007, 03:47 PM
Thanks very much for your help. I am going to check it out this week. I will post with results later this week.
Old 09-23-2007, 06:28 AM
Well, I finally got around to installing the resistor block. It cost me about $48 from the local dealer, went in very easy. The two bolts to remove the resistor block were 1/4". I used a socket/rachet. I had the most problem with getting one of the four small screw/bolts back in from the cover that had to be removed first. It is the second one from the driver's side and it is in a well of about 1-1/2". Part of the problem also is the access to it is somewhat blocked by the close proximity of the floor. After stuggling with it for about 15 minutes, I ended up using a small strip of duct tape to hold the screw onto the end of the 7mm socket, allowing the screw to stay straight or parallel with the socket, then I was able to insert the screw into the hole for it. It took me longer to replace the cover and the cover screws than to change out the resistor block. Thank you silicon212. It worked out great!!!
