Old 08-10-2007, 07:34 PM
mbazid mbazid is offline
Is it the Alternator
The battery light came on when my wife was driving than the other lights came on and the windows stopped working. When I went to take a look the van needed to be jump started and the battery light came on followed by the other lights on the dash. any clues?
Old 08-10-2007, 08:46 PM
rodeo02 rodeo02 is offline
Re: Is it the Alternator
How old is the battery? That would be my first suspect. It could be any part of the charging system; Battery, battery cable, alternator, etc..
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 08-11-2007, 06:35 AM
orkel orkel is offline
Hi mbazid
This seems to be a pretty common problem with the Windstar, see my tread at http://www.automotiveforums.com/vbul...d.php?t=734702
I had the exact same problem, and it ended up being the alternator.
Obviously though, if you have a voltmeter, please do a couple simple tests as others in this forum have suggested. Just do a search for 'alternator and battery', that way I don't have to repeat the excellant advise already given by others
Old 08-11-2007, 08:41 AM
busboy4 busboy4 is offline
I'm sure you probably know, but if you still suspect the alternator, take it into an autozone or similar store. They can put it on a test rig and check it before you go to the expense of replacing it.
Good luck
Old 08-11-2007, 10:18 AM
wiswind wiswind is offline
Make sure that the battery is in good shape also.
A weak battery can place a significant load on the alternator, and you don't want to burn out the new alternator.
My '96 also has a alternator fuse in the engine compartment fuse / relay box.....aka power distribution box.
It is fuse "T"
Check your documentation for other years.
I would recommend a "electrical check" at your local auto part store....they will do this for free, on the vehicle.
I have a AutoZone Duralast "Gold" battery that was reasonable in price....and has a good Cold Cranking Amps rating.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
