Old 08-10-2007, 06:00 PM
sebaz sebaz is offline
Need help removing something
That plastic part that is at the bottom of the door frames in the interior, so I can pull up the carpet a little bit and pass cables from the stereo to the amplifier (which I will install below the passenger seat) and from that amp to the subwoofer in the trunk. Does anybody know how to remove that plastic frame? The part that goes in the back seat area seems easy to lift, but not so much the front.
Thanks
Sebastian Alvarez
Old 08-10-2007, 06:38 PM
maxwedge maxwedge is offline
A990 racer
Re: Need help removing something
Do you mean the sill plates. if so pry them up they have clips that secure them to the rocker panel.
Old 08-10-2007, 07:22 PM
The front part of it seems to have something stronger than a clip because I tried to pry it out and it seemed really attached to something and I thought I was going to break it if I kept pulling.
Sebastian Alvarez
Old 08-10-2007, 11:28 PM
Blue Bowtie's Avatar
Registered Offender
What year? Some versions have the thresholds screwed in place.
Old 08-11-2007, 05:25 AM
1994
Sebastian Alvarez
Old 08-12-2007, 06:13 AM
GringoPete's Avatar
GringoPete GringoPete is offline
Sebaz, You dont need to remove the entire piece. It will be easier if you actually just pry the edge starting from the front and tucking the wires inside as you work your way towards the back. I have a panel puller (mini pry bar) that i used to use for this operation.
It looks like this:
Good Luck,
Pete
